Hi I have a project where I am running aa PowerShell script to update a property file. when I am installing it updates property file fine. now the problem is after installation I just edited, the updated property file (like changed some text and values).
Now I am going control panel and clicked on repair/ Reinstall at that time it is not updating the property file it is as what I edited last.
I added code in maintenance
if variable REPAIR equals TRUE
RUN powershell
End
but it is not working. I am able to see the powershell windows appears but the functionality written in ps file is not executing properly. if you want I will share my project with you.
also I went through some posts but it didn't helped me.
viewtopic.php?t=5029
this post is describing my problem, I am facing same problem decribed in this post.
