Second Install Splash Screen (IA Studio X12)
wwanko
Post by wwanko »
Hi everybody,
I just updated from IA 8 to IA X12 and was opening my setups in the new version.
Everything looks great so far except one thing:
As soon as a Setup is launched there are two splash screens. In the old IA 8 the splashscreens 1 and 2 looked like this:
Now with the new X12 the second splash screen looks like it wouldn't belong to the installer. See
Mind you, I don't have any issues with the text or the IA logo. I just want its background to be the same as the first splash.
I even tried some new Setups with different themes but the second splash alwas looks the same.
Any insight would be greatly appreciated!
Wolfgang
Re: Second Install Splash Screen (IA Studio X12)
It's not possible to override the Dialog Theme of the second initialization dialog.
However, you may set the CLOAK_DIALOG_LOADER = TRUE (pre-defined compiler variable) to suppress the setup loader dialog (the second initialization dialog).
It may be useful to set the "CLOAK_DIALOG_LOADER" variable in combination with "MIN_EXTRACT = AUTO".
I suggest you to have a look at the IA documentation for important details about those pre-defined compiler variables.
wwanko
Post by wwanko »
This pointed me into the right direction! Thank you Francesco, problem solved!
Now I just have to read the rest of the documentation and catch up on all the other great things this software can do...
:D
:D :D :D
