How to add new script to be included in main?
digibum
Post by digibum »
How would I add a new script that would be included from main script?
I would like to break my large main script to more smaller ones for easy management.
Thank you.
Using IA X11 Developer
Re: How to add new script to be included in main?
Sure you can.
From IA IDE, switch to MSICode view, right click the "Include Scripts" node in the left tree pane, and then "Create New script". This will add a new Blank Script File to your Project.
Finally, use the "Include Script" command to invoke your new script from your main setup script.
digibum
Post by digibum »
Awesome, thank you!
