Demo version message when built with miabuild.exe
pableess
Post by pableess »
I am using miabuild.exe to build my project on a separate build machine which does not have IA installed. The built project contains the message about the installer being built with the demo version. Do I need to have another licensed copy in order to accomplish this without that message???
Also with miabuild.exe, what do I need to put it on another machine and make sure that it will include the checks and installs for prerequisites???
For your first question, you need to run the InstallAware Licensing Wizard on your build machines before attempting builds.
As for the second; be sure you do a full install of InstallAware - at least one that includes all the pre-reqs you are interested in. That guarantees your setups will build successfully.
