Example for pre-/(post-build event commands
anja_laenge
Postby anja_laenge » Tue Mar 23, 2021 3:57 am
my goal:
I'd like to utilize the post-build event to write a simple textfile to the Relesase folder with a naming convention like <buildmode>_<yyyyMMdd_HHmmss>.txt containing Productcode and RevisionCode.
edit: I got most issues solved using a custom console app. Remaining is, how to access the projects product and revision code here?
kind regards
Anja
Re: Example for pre-/(post-build event commands
Postby FrancescoT » Tue Mar 23, 2021 12:01 pm
You may use custom compiler variables. These should be defined with the project, and then via build event, these "Custom compiler varialables" should be then passed as command line parameters to your custom console app.
anja_laenge
Postby anja_laenge » Wed Mar 24, 2021 3:13 am
FrancescoT wrote:You may use custom compiler variables. These should be defined with the project, and then via build event, these "Custom compiler varialables" should be then passed as command line parameters to your custom console app.
Thank you and kind regards
Anja
Users browsing this forum: No registered users and 128 guests
