Installation as System User with IA X12
anja_laenge
Post by anja_laenge »
I have a working IA setup, build with IA X12 using Aero theme.
This setup does not work correctly when executed as System user (reproduced with psexec).
Applying ALLUSERS = TRUE as default, changing Aero to Official and applying code modifications from viewtopic.php?f=2&t=10656 did not change the behavior.
The result after setup execution:
- the program is listed in the control panel
- the uninstall start menu link is created
- the registry entry under HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\ is created, pointing to the expected default InstallLocation under C:\Program Files (x86)
- at the indicated InstallLacation no files or folders exist
- no desktop links
- no other start menu links
What am I missing here?
kind regards
Anja
EDIT:
logging the setup execution, I have entries like
MSI (s) (B8:14) [13:33:06:949]: SECREPAIR: Failed to open the file:C:\Windows\Temp\mia1\OFFLINE\3BE32701\147329ED\filename.dll for computing its hash. Error:3
MSI (s) (B8:14) [13:33:06:950]: SECUREREPAIR: Failed to CreateContentHash of the file: OFFLINE\3BE32701\147329ED\filename.dll: for computing its hash. Error: 3
MSI (s) (B8:14) [13:33:06:951]: SECREPAIR: Hash Value for the file:OFFLINE\3BE32701\147329ED\filename.dll is:
MSI (s) (B8:34) [13:33:56:652]: Executing op: ComponentRegister(ComponentId={BB9B98C2-CA88-4A12-AC2D-81C3BC3F8F95},KeyPath=C:\Program Files (x86)\target\de\filename.dll,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (B8:34) [13:33:56:657]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\target\de\filename.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
('target' and 'filename' are my replacements)
Re: Installation as System User with IA X12
Dear Anja,
are you querying both "System->Desktop" and "Start Menu->Programs" folder locations For All Users?
anja_laenge
FrancescoT wrote:Dear Anja,
I am using the recommendations from the post mentioned above:
Get Common Folder Location Start Menu->Programs Group into SHORTCUTFILESALL
Get Folder Location Start Menu->Programs Group into SHORTCUTFILES
if Variable SHORTCUTFILESALL Equals
  Set Variable SHORTCUTFILESALL to $SHORTCUTFILES$
if Variable ALLUSERS Equals TRUE
  Set Variable SHORTCUTFOLDER to $SHORTCUTFILESALL$\$STARTMENU$
  Get Common Folder Location System->Desktop Directory into DESKTOPDIR
else
  Set Variable SHORTCUTFOLDER to $SHORTCUTFILES$\$STARTMENU$
  Get Folder Location System->Desktop Directory into DESKTOPDIR
second part before installation process.
I would understand, if there'd be something blocking the complete setup.
But...
registry uninstall is written correctly, the target folder does not even exist, the log shows the cited items for failed, error, blocked etc
I am confused;
what could be the reasons for the control panel reporting success while various actions required to transfer files to the destination are blocked and fail, and as a consequence the destination folder does not exist?
EDIT: Must the setup be signed?
kind regards
Anja
Dear Anja,
there are a few things which are not totally clear to me.
Are you sure the problem you are reporting is directly related to the Administrative installation mode? Does the setup work fine when installing as PER-MACHINE or PER-USER?
Are you using a CLEAN MACHINE (where exclusively the OS is installed - no other software) to test the package?
anja_laenge
Hello Francesco,
FrancescoT wrote: oes the setup work fine when installing as PER-MACHINE or PER-USER?
All our setups are per-machine.
the setup works
- with ui
- silent
- silent as local admin
a very basic clean testing platform.
Apart from all other aspects: what could be causes for the cited log entries?
kind regards
Anja
anja_laenge
anja_laenge wrote:Hello Francesco,
the setup works
- with ui
- silent
- what could be causes for the cited log entries?
- must a system user setup be signed?
kind regards
Anja
anja_laenge
Hello Francesco,
the setup works
- with ui
- silent
kind regards
Anja[/quote][/quote]
Dear Anja,
I don't think the issue may be due the signature.
Could you please post the complete log file? I'd like to take a look at it
anja_laenge
Hello Francesco,
I have completely recreated the project and it works now.
I didn't want to post the log here because it contains sensitive data and is 64 MB in size.
Another question: I see a full variable dump in the log; is there any way to do something like this via the custom log script without entering all variables manually?
ind regards
Anja
Unfortunately there isn't a built-in method for this.
