I have a very simple installer that behaves in a weird way. For certain verisons of the application, as defined in InstallAware, every time I try to install the application I get an empty "Error" dialog. If I change the version by adding "-SNAPSHOT" and I rebuild the .exe, it works.
The application requires "Always Elevate (requireAdministrator)"
Any suggestions are highly appreciated.
Empty Error dialog
Re: Empty Error dialog
In all honesty, I have no idea of what "-SNAPSHOT" is for or what this should do.
I can only suppose it's a custom keyword you introduced for some reason.
You should try to describe the problem a bit more clearly and in details.
Hi Francesco,
SNAPSHOT is just an arbitrary string and any other string can be used. That was just an example.
Not sure how much detail I can provide. The problem is very simple. We have a very basic installer that sometimes can be ran without any problems, and sometimes, just by changing the version to something else and rebuilding the installer it throws that empty "Error' dialog box.
One thing that is consistent is that the error only happens when the user running the installer is not an admin, and enters an admin user's credentials for the install, when prompted. The application requires "Always Elevate (requireAdministrator)"
Please let me know what other details are needed, and I'll be happy to provide them, if possible.
Victor.
Victor.
unfortunately, I cannot give any help given the details you provided.
Alternatively, You may share a VERY VERY MINIMAL setup project that replicates the issue (including the necessary reproduction steps).
Hi Francesco,
Please find attached 3 files.
The one named "installer_test.zip" is the source for a test setup project that exibits the behavior I was talking about.
The zip filed named "executables.zip" containes 2 executables built with the same project. One has the verison 3.0.22 and this is the one that pops up the empty error dialog, the 2nd one has the version 3.0.22_FT, and this one installs correctly. The only difference between the 2 is the version (FT is just a random string, but anything can be used).
The 3rd file named "error.doc" is just a screenshot of the error dialog I'm getting.
This behavior happens only if the executable is run on a machine where the login user doesn't have admin priviledges, and enters admin credentials when prompted by the installer.
Please let me know if there is anything else I should provide.
Victor.
Victor.
- error.docx
- (40.54 KiB) Downloaded 1381 times
- installer_test.zip
- (734.79 KiB) Downloaded 1343 times
- executables.zip
- (4.13 MiB) Downloaded 1441 times
Dear Victor,
I cannot reproduce any issue. I simply built your project as it is, and it worked as expected when executed from a non administrative account (once elevated, of course).
- (685.78 KiB) Downloaded 1223 times
- Installer.zip
- (2.1 MiB) Downloaded 1132 times
