Call Sub installer From Main Installer [URGENT]
muddasirqdiwai
Post by muddasirqdiwai »
hi evry 1 i hope evry 1 has seen Microsoft SQL server 2000 installer it has main screen from which we can choose sub installer [component]
I want to do the same thing like that i have 4 sub installer which can install on any PC, i want to have Main screen or Installer which shows me 4 option [sub installer] and select one of those installer and execute..
That main screen cannot be installer becoz it has to execute as well that my opinion
can any 1 help me OUT
with regards
neillans
Post by neillans »
Sounds like you are after an Autorun menu; a single form application with a numer of options - each option fires a different installer / application / whatever.
If this is what you want, you can knock one up in any language you use, or google for a program that will do it for you.
Andy
Also, did you try the CD Autorun template? That would get exactly what you want done for you.
