Hey,
Just wanted to share a small discovery I had regarding Run .NET installer class:
If the path to your windows service EXE file is long (i.e. with spaces, etc) both "Run .NET installer class" and Run Program for InstallUtil.exe will not work unless you use the Convert Path command.
I did not try to add " before and after the command, it might work aswell.
Ben.
