Floating license
steven
Floating license
Postby steven » Wed Jan 10, 2007 5:02 am
A simple question :
I want to buy the Studio version and install it on multiple computers for my project team , I need a floating license ?
If yes, there is a limit on this number computers ?
For example InstallShield has a limit of 10 pc.
I can buy the Studio Competitive Upgrade version ( 599 $ ) ,the floating license additional cost is 599/2 or 899/2 ?
Postby CandiceJones » Wed Jan 10, 2007 5:27 pm
Hi Steven,
Because you will be competitively upgrading, your license cost will only be $599 - competitive upgrade product.
To add a floating option on top of this license, you will incur an additional cost of only $449 - this is the "upgrade" product in the online store.
There is no restriction on the number of systems where you can "float" the license.
Additionally, there is no limitation on the number of build machines you can use to build your setups with Studio - this you get "for free" even without a floating license.
Return to “Non-Technical”
Users browsing this forum: No registered users and 69 guests
