The field InstallLocation is blank. If I attempt to use WriteRegistry to populate that key it doesn't work (either before or after Apply Install). I have to use "reg.exe" to get around that.
Should I Apply Install again, a second time? Any ideas what I might be doing wrong greatly appreciated?
Hi, we have the same problem with our installer. InstallLocation is empty and UninstallString is missing in HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall
Do you have any suggestions, what might we be doing wrong?
