When you need to make sure that the .net framework is installed and install it the seup program blows out to a very big size. I change the script so instead of installing the framework it prompts the user to download it from Microsoft Web site.
So here is what I do
Use a messagbox to prompt the use with the message (you need .net do you want to download it or terminate now)
Then I check the variable is equal to Yes for download
Actually, with web builds, you'd save even more space.
A web build will not include the .NET runtime inside the main setup, and it will download it from the web, on-the-fly, only if required.
Moreover when it is required, it will download only 10.5 MB, instead of 23 MB. The same runtime just compresses a lot smaller with InstallAware.
So thanks for the script, but the best solution here would be to do a web build, in my opinion.
