Silent distribution problem
mjtolva
Post by mjtolva »
I am trying to silently deploy an app that was externally packaged with InstallAware.
I ran the .exe with a /S on the command line and it runs for a few minutes then stop. It seems extract a bunch of files to the %TEMP% folder then stops.
Any ideas on how I can automate this install?
You want to review your silent install logic to determine where setup is bailing out. You may want to customize your logic for when SILENT is TRUE.
mjtolva
Post by mjtolva »
Sorry but I don't know what that means.
I didn't create the install, and am not familiar with how InstallAware works.
Then, please contact the setup author for further help.
