Getting started
docuxplorer_ins
Getting started
Post by docuxplorer_ins »
I am new to install programs as well as InstallAware.
Is there a tutorial yet for getting started?
I don't know what to add to each section.
For example, I want to start simple. I have a small MS Word document in a folder on my hard drive. I would like to install it using your program to a different folder. Next, I want to update the MS Word document using the install program.
Can I do this from the hard drive or do I need a website?
What steps do I do to get this done?
I tried the wizard and I think I was able to install the MS Word document but I am not sure. I then tried to update it using InstallAware but there were no messages and nothing happened.
Any help would be appreciated.
Thank you,
Art Sterling
[email protected]
Hi Art,
Try the new Quick Start wizard available with InstallAware 6.6.
Also, check this page out:
http://www.installaware.com/publication ... guides.htm
