How to set a minimum requirement for Windows XP with SP2
JasonCrone
Post by JasonCrone »
We will be creating another installer, but for this one they do not want to require a MS .NET Framework version but they require at least Windows XP with SP2. Is there any way to check for this? Can this be added to the Application Information > Application Requirements screen? On the minimum for IE there are all of the versions with each service pack, but for the minimum OS there is no check for SP's. I am not sure if this is even possible, but it would be nice if it was.
Any feedback would be appriciated, especially some help/advice on my actual question!
jimo
Post by jimo »
Try this:
Get System Setting Windows XP into CHECKSYSTEM
 if Variable CHECKSYSTEM not Equals TRUE
   MessageBox: $TITLE$ Setup Error, This product requires at least Windows XP.$NEWLINE$$NEWLINE$Setup cannot continue.
   Terminate Installation
   else
   Get System Setting Service Pack 2 into CHECKSYSTEM
   if Variable CHECKSYSTEM Equals TRUE
     MessageBox: $TITLE$ Setup, Windows XP with Service Pack 2
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
