Convert Wise script to IA
Post complete new themes or wizard dialogs here.
get101
Post by get101 »
I am changing from Wise Installer to IA Studio.
Can you give me any ideas on where I should start? I want to convert these lines from my Wise script into IA.
If File Exists %INST%\\start.af then
     Copy Local File from %INST%\\start.af to %MAINDIR%\\start.ini
Else
 IF THESERNO Equals "100" then
   If File Exists %MAINDIR%\\start100.ini then
     Copy Local File from %MAINDIR%\\start100.ini to %MAINDIR%\\start.ini
   End
 End
 IF THESERNO Equals "200" then
   If File Exists %MAINDIR%\\start200.ini then
     Copy Local File from %MAINDIR%\\start200.ini to %MAINDIR%\\start.ini
   End
 End
End
For this, use the direct script conversion tool. There is also another tool which converts your setup as a whole, but it will lose custom code like this.
