Registering DLL is a mystery
get101
Post by get101 »
Can I get some basic help on how to register DLLs and OCXs please?
I've read other messages in the forum and I'm puzzled.
I went to Registry, and then clicked Import.
Now what do I do?
(This is what I did, but I guess its wrong because it didn't do anything: I selected one of the DLL files in my installation directory).
I am converting a Wise script into IA. I tried importing it to see if it would reveal what was needed. But that simply marked every file as Self registering, so it was no help at all.
I have no idea what to do next. Can you help by giving me a simple, really basic, step by step guide? I have about 15 dlls and ocxs.
Edhy
Post by Edhy »
Here how I do register mine, after the Apply Install command:
        Comment: Progytech: Register .OCX files
        Register Library $TARGETDIR$\\ctExplorer.ocx
        Register Library $TARGETDIR$\\Io.ocx
        Register Library $TARGETDIR$\\ctToolBar.ocx
        Register Library $TARGETDIR$\\VRep\\Distribution\\ctmonth.ocx
        Comment: Progytech: Register the .NET library cdrCryptoLib.dll
        Run Program $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\RegAsm.exe $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\CDRcryptolib.dll /silent /codebase  (WAIT)
        Install Fonts from '$TARGETDIR$\\Fonts\\*.ttf'
        Comment: If this installation includes the cdrServer, then Start the cdrService Monitor
        if Variable USE_CDR_SERVER Equals TRUE
          Run Program $BootDrive$\\Progytech\\ezCallTrack\\cdrServer\\cdrServiceMonitor.exe
          Comment: MessageBox: $TITLE$, The cdrServer has been installed on this workstation.$NEWLINE$Start the service by righ click the "ezCallTrack Service Monitor" icon on the right side of your monitor and choose Start Service.
Edhy Rijo
get101
Post by get101 »
Edhy wrote:Hi,
Hi Edhy
Thanks for this.
Looking at the Help for Register Library, it says:
Files you self register with this command during an installation must be explicitly unregistered when they are being removed.
I assume that this applies to your example. Do you know how one does that?
Also, Install Fonts does not show up as an IA command, nor is it in the Help file. Where did you find information on Install Fonts?
Thanks again for your help.
Edhy
Post by Edhy »
About the registration of the libraries, I guess you are right, in my case, it does not matter if the libraries are still registered when uninstalling, but I will check on that in order to keep the system as clean as possible at uninstall.
About the Install Font, check the Plug-In Development forum, there a couple of good ones there. Markus Diettrich an InstallAware MVP is the creator for mdPLUGINS for InstallAware wich includes the Install Fonts. Here is the direct link:
http://www.casic.de/Tools/mdPLUGINS_for ... re_en.html
Edhy Rijo
jimo
Post by jimo »
Use the same set of commands just mark the Unregister option in the "Register Library" command.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
get101
Post by get101 »
jimo wrote:Use the same set of commands just mark the Unregister option in the "Register Library" command.
Where does one add this to the script? Please see below: Is this correct?
if Variable REMOVE Equals TRUE
   Apply Uninstall (get result into variable Success)
   Set Variable PROGRESS to 100
   if Variable SUCCESS Equals TRUE
      if Variable SUCCESS not Equals Cancel
         Unregister Library $TARGETDIR$\\Comctl32.ocx
         Unregister Library $TARGETDIR$\\Richtx3232.ocx
