Run program only when specific feature is installed
EricB
Post by EricB »
I have an install with 3 features. If a specific feature is installed, I need to run a batch file.
What is the best way to accomplish this task?
Eric
pfennig
Post by pfennig »
Initialize a variable of your choice to false. Set it to true at the end of your feature's script block. Later run the batch file if that variable is true.
EricB
Post by EricB »
pfenning,
Thanks for the reply. After playing around with IA in the daytime hours rather than late at night when the brain is fried, and taking your advice, I able to do what I wanted.
Thanks again,
Eric
