Setting an install's Product Version programatically
Is it possible to set a project's product version by a compiler variable or other means? We are trying to automate the generation of our installs, and having to update the product version from the GUI makes this difficult at best.
Sure, you can use Compiler Variables for the version field. Just remember to dereference the variable in the form #Variable#
Alejandro Ronquillo
If I enter e.g. #MY_VERSION# into the Product Version field in Project Properties, a message pops up:
I guess this would be safely ignored, because the following procedure works:
In Compiler Variables, I have defined MY_VERSION and assigned it a default value.
Then, I build the IA project with the following command line:
and the build completed successfully, with the expected version indicated when I open properties for the generated installer exe.
Incorrect Product Version Value
Only numbers and periods are allowed in this field.
miabuild.exe myproject.mpr /b=0 MY_VERSION=1.2.3.456
If you read the help file contents topic "Using Compiler Variables" you will see:
Therefore the error message cannot be considered a bug
You can always use compiler variables where regular string expressions are allowed, even if regular (script) variables have been prohibited.
Alejandro Ronquillo
Users browsing this forum: No registered users and 132 guests
