Source code changes do not effect changes in the executable.
hjage
Post by hjage »
I'm just testing InstallAware Version 7.0 and I 've seen this strange behaviour.
After changing my source code in the MSICode editor
for example:
changing the title in a message box
I saved the project and started the single file build.
Then I started the run of the single file but this change of the message box
didn't appear. I only saw the status before this change.
Gizm0
Post by Gizm0 »
Are you sure you're running the correct file? As you understand this thing is impossible to happen.
Panagiotis Kefalidis
Software Design Team Lead
