Hello
I use Installaware 6 Express and have problems to install the BDE correctly.
I have loaded the BDE_PRO.MSM and add it under Development -> Merge Modul.
BDE get installed and uninstalled...but i think not correct.
I also installed bde_prequisites
with following data:
setupbde52.mia
checkbde52.mia
Borland Database Engine 5.2.rtm
But when i check this Option under Applicationruntime
i get following error
InstallAware File Bag Plug-In
Warning!
No files matching wildcard pattern <replace>
Has someone some tips?
Alex
