Hi all!
Whenever I run a installer that downloads MS.NET 2.0 SP2 Web Media Block the installation fails with "Unable to load plug-in library" message box. ( message attached...)
I've tried with 2 separate IA projects and both fails during extraction of the downloaded runtime.
If I remove the .NET requirement the installer works but this is a bad solution for me.
Build Environment:
IA 8
Target machines:
WinXP SP3 with .NET 2.0 SP1 & .NET 3.0 SP1 & .NET 3.5
Win2K3 SP2 with .NET 2.0 SP1 & .NET 3.0 SP1 & .NET 3.5
Any ideas or thought folks?
Unable to load plugin-library/.NET 2.0 SP 1 Req/Media Block
Has anyone ever done a successful download, extraction and installation of .NET Framework 3.5 SP1 ( and related ) web media blocks?
( the previous runtime .NET 3.5 including 2.0SP1 & 3.0SP1 worked just fine )
If I embed the runtime(s) in the installer everything works just fine, but a download of the runtime as a web media block ALWAYS FAILS during the extraction phase with a missing plug-in error.
I'm lost here - I reinstalled IA8 from scratch, I recompiled the media blocks but with no luck.
Anyone?...please?...
