Get INI File will not accept a path encased in quotes
sdeschenes
Post by sdeschenes »
In my particular scenario, my installation needs to traverse a bunch of folders in search of a file named config.txt. I don't know the names of these folders, so I use the "Find All Files". In this instance, the returned path to this file contains embedded spaces, so the path is wrapped in quotes. Now, I need to get a value from this file, so I use the "Get INI File Settings" command. When I pass the full path to the file and return the value from the file, I get an empty string. I have determined that "Get INI File Settings" will not accept a path that is encased in quotes.
I currently have a workaround in place, whcih is parsing the string and removing the quotes, but I shouldn't have to do this. The "Get INI File Settings" function should be able to accept a path wrapped in quotes.
