If Variable MYVAR not is Defined
Set Variable MYVAR to some value
then click the compile button, I get a Compile Error: "Variable not defined: MYVAR." Yeah, I know. That's what I was testing for. Is this how this is supposed to work?
I see, thanks! I don't want the value to persist, though. What I was trying to do was check if a value was passed in on the command line, and set it to a default value if it wasn't. The solution I found in another thread was to do this:
