Group Policy from cmdline - can it be totally silent?
jsmith
Post by jsmith »
When running the Group Policy wizard from the command line, is there any way to:
1. Make it not pop up the little "Processing, please wait..." dialog? The dialog isn't branded as being part of InstallAware in any way, and it doesn't quite fit with the idea of running something silently in command-line mode. The chm file says, "When run from the command line, the wizard does not display any prompts or require any user interaction." It may not be prompting for input, but it is displaying something.
2. Make it not display the GUI version of the Wizard if anything is wrong with the command? Again, the help says, "When run from the command line, the wizard does not display any prompts or require any user interaction." But this isn't true if there's an error, such as the setup.exe to package can't be found. In that case it prompts, even though it was run from the command line. The wizard returns code 1 on failure, so why pop up the GUI?
