Second destination
Second destination
I have an application that requires the installer to enter 2 paths - one for the application code, and one for the resulting data... how can I prompt for the data path ?
With a custom dialog that contains fields for both paths or two custom dialogs which allow you to enter them individually.
You don't need Admin, you can do this with Studio as well.
Let me know if you need instructions still.
I can provide these, along with a sample project actually which contains everything built-in, immediately after your Studio purchase.
Re: Second destination
I have the same problem/issue to solve:
I will have an application that requires the installer to enter two paths - one for the application and one for the data ... how can I prompt for the data path including to display Remaining Disk Space correctly?
Is it possible to receive instructions and/or sample code/projekt? Thx in advance ...
Evaluating InstallAware ...
For each path you want to allow users to choose:
Now, when the user clicks on the buttons, the paths they choose will be set to the appropriate edit controls. You can make as many of these as you like.
Note that it's best to set the text of the edit controls to blank by default.
- Add an edit (textbox) control and a button control.
- Double-click on the button and set its Performs Action property to Select Custom Folder.
- Choose the associated edit control from the Control drop-down or double-click on it on the dialog editor.
- For the edit control's Receives Information property, choose [Written Variable Value].
- For the edit control's Writes Value to Variable property, choose <name of associated button>. So if Button1 and Edit1 are associated, then you would put "Button1" (less quotes).
Users browsing this forum: No registered users and 63 guests
