Error during build
culbertb
Error during build
Postby culbertb » Tue Apr 21, 2009 2:41 pm
I'm testing IA and have not been able to create a successful install yet. I get a message to check the log file. The log file is attached. Any help would be apprecaited.
I have looked through the forum and have not seen anything yet.
BC
Downtime Specimen Manager 2009.log
Postby CandiceJones » Tue Apr 21, 2009 3:02 pm
Did you just try to build a tabula rasa basic setup project and see what happens with it?
culbertb
How
Postby culbertb » Tue Apr 21, 2009 7:38 pm
Where can I find information on building a "tabula rasa basic setup project" ?
I've done a quick project from the IA admin screen and this wsa from the Visual Basic plug in.
bokkie
Postby bokkie » Wed Apr 22, 2009 2:30 am
Tabula rasa = clean slate, blank canvas.
What Candice is suggesting is that you consider starting a new project and add the installation elements one at a time to see if you can identify where it breaks. The other angle she might be hinting at is to create a basic project and build it immediately after you've created it. Don't add anything and don't delete anything. That'll prove if an off-the-shelf project is failing as well.
Have you tried debugging the script in your project?
Return to “Non-Technical”
Users browsing this forum: No registered users and 8 guests
