HELP! corrupted installation (IA8) but not really...
dinko
Post by dinko »
Im trying to install IA8 (InstallAware_8_With_Runtimes.exe) in my new Windows 7 RC (64bit) and I get message:
InstallAware Wizard
Cannot start setup - the setup file may be corrupt, or you may have the wrong password. If you downloaded this file, please download a fresh copy. If the file is password protected, check your password and try again.
OK
Im sure I have the correct password and the file is not corrupted because I just installed on my other pc Vista 32bit.
I tried to install using compatibility mode to Vista, to XP everything. I also installed Windows XP virtual PC and same error occurs. I also tried with run as administrator. UAC is disabled.
Maybe because of Windows 64bit host operating system?
Any idea how to solve the provlem? Or transfer the already installed IA from my Vista to new machine?
