Uninstall MSI Package
AH-NP
Post by AH-NP »
I try to uninstall an application with the plug in Uninstall MSI Package, I use REMOVE=ALL, I select “use packages Guid” with the Product Code of application and I check “Package is InstallAware generated installation”. The uninstallation is Ok, but in Add / remove programs the ProductName of the application is always present. Have you a solution ?
Please do not post the same topic in multiple places. Thank you.
