Is there a possibility to redirect the output of the miabuild.exe dialog window to a log file?
This would make finding build problems easier when running in batch mode.
Creating Logfiles when using miabuild.exe
Hi
This is easy to do from the command line, just do a redirection. For instance:
Will output the entire contents of the build window to the file output.txt at the end of the build process. While during build this information is written to a window, after the build completes, miabuild.exe dumps the entire contents of that window out to the command line, so you can just use regular command line redirection here.
miabuild.exe [your parameters] > output.txtMichael Nesmith
