Convert variable to lowercase
viponly
Postby viponly » Fri Jan 13, 2006 12:51 pm
I'm reading a value in the registry and putting it in to a variable. I need to convert the value in the variable to all lower case. How can I do it with InstallAware? Thanks.
Postby MichaelNesmith » Fri Jan 13, 2006 2:15 pm
There is no easy way to do this...sorry.
What will you be using this variable name with? Remember that file names, etc. are not case sensitive.
That said if you need to replace specific characters you could do so using the Replace String command. You could even write an include script to replace every character in the alphabet with its lower case counterpart...and use that to achieve your task. But there is no pre-built function...
Users browsing this forum: No registered users and 64 guests
