Dialog Editor
paul.fitzpatrick@avondata
Dialog Editor
Post by paul.fitzpatrick@avondata »
Can I use an animated GIF on the progressprereq and progress dialogs? If so, how can I do this?
Alternatively, I notice that you can use a flash image, if this is my only option to show any type of animation or presentation (without using html and the web?) If so, does it need to be a particular version of flash? And will the end user need to have flash pre-installed to view the presentation?
Paul Fitzpatrick
neillans
Post by neillans »
Hi Paul,
The best bet is to use Flash as this gives you more flexibility.
End users do not need to have the Flash runtime installed.
You should target version 6 for the swf to work in InstallAware.
Andy Neillans
I have created my movie.swf file in Flash CS3, and saved it as a flash file in version 6, added it my creatives area (which added a flash.ocx file).
This does not work? The flash screens come up blank - What could I be doing wrong? Do I need to create a particular flash project type and convert to flash version 6 or should I target a particular action script version too?
Any help would be graciously received.
neillans
Post by neillans »
Afraid there is little to go on with your information provided ... can you submit your fla file through our support system?
Andy Neillans
The answer
This problem is a caused by a setting in the FlashFrame, all I did was double click on FlashFrame which opened a settings page; then you change the Receives Information drop down to display 'Installation Billboards'
