Run Program As not working
richard
Postby richard » Wed Jan 18, 2006 12:40 am
When i use the "Run Program" command the app runs fine except that i need the startup dir to be set.
When i use the "Run Program As" setting the startup directory the app does not start.
I have checked the command has been added to the code in the correct place.
Any help here greatly appreciated
Cheers
Richard
Postby MichaelNesmith » Wed Jan 18, 2006 9:17 am
For some applications (ex: .NET applications), setting this startup field does not seem to be sufficient, but an actual SetCurrentDirectoryA call is required to set the current directory on the system before calling Run Program or Run Program As. This is not a Run Program As bug, but apparently a limitation in either the API or the applications in question.
Just call SetCurrentDirectoryA Win32 API using Call DLL Function to work around this issue - this function is found in kernel32.dll, takes a single pointer to string parameter (the directory to switch to, such as $TARGETDIR$), and returns a bool.
Users browsing this forum: No registered users and 144 guests
