Possible to change default save location?
brad.huffman
Post by brad.huffman »
Is it possible to change the default location that setups are created in? I'm in the beginning stages of setup development, and will be creating several test projects to try out various setup features. Rather than having those projects clutter up my My Documents folder, can the default save location be changed to something else (My Documents\\InstallAware Projects perhaps)? Thx.
iti
Post by iti »
you can set the default build directory in the "Deployment >> Build Settings" Section under "Output". Simply choose a custom folder.
