Hello!
When building from the commandline (with miabuild.exe) the compiler doesn´t check for 'LABEL statements cannot be nested inside loops/conditionals'.
This is very annoying as the resulting exe crashes with an 'Access violation at address 74DD0B09. Read of address 74DD0B09.'!
When building from the GUI the error is reported correctly and no exe is created.
Crash when built from commandline
Hi Mike
The command line build tool does not do a "compile test" - I apologize for the inconvenience. The IDE should be used for testing scripts and the command line build tool for building setups.
