Features
kkchan
Features
Post by kkchan »
Hi
I would like to use Setup feature to let users to choose what module to be installed. I have a component/feature "TaskManager" which would be used by some feature (Module A) but not all. How could I auto select the Task Manager feature whenever I select Module A?
Thank you
bokkie
Re: Features
Post by bokkie »
A quick thought: would setting and checking a value for INSTALLLEVEL help?
kkchan
Re: Features
Post by kkchan »
Hi
any sample?
bokkie
Re: Features
Post by bokkie »
It was a Homer Simpson thought I had. INSTALLLEVEL was I think something in InstallShield. I can't remember now how you conditionally install features in IA. I'm sure it can be done, possibly by using a setting up a compiler variable and checking it where the feature is used in the script. You'd be better off letting someone else comment. Sorry!
