Hi!
Can I show the Language Selector only if the setup.exe is started without a parameter?
This is needed because we use a autorun that starts either 'setup.exe LANGUAGE=German' or 'setup.exe LANGUAGE=English' and so the language selector is only needed when the user starts the setup.exe manually.
Problem with Language Selector
Hi Mike!
I think you want to look at the multi-lingual setups example to see how you can create and show your custom language selection dialog from code, at runtime.
The built-in dialog cannot be tweaked in the manner described, but you may always use the custom selection dialog instead.
Users browsing this forum: No registered users and 120 guests
