When I run the build miabuild.exe hangs. I have used sysinternals process explorer and looking at the call stack miabuild.exe seems to be waiting for some mouse input. Obviously it won't get any as it is a service that is calling it
When I run miabuild.exe from a command line with the same parameters used by FinalBuilder everything runs fine and there are no prompts for any input.
What could be causing miabuild.exe to hang? Assuming it is actually waiting for mouse input, why would that be?
Another related question. I have turned of Authenticode as it seems like this causes some dialogs to appear. If this is correct will it be possible to turn it back on successfully when running as a service?
Using IA 9 (build Moya sp1.070409)
Cheers, Lars
