SQL CE 4 Support
shanep
SQL CE 4 Support
Postby shanep » Tue Feb 08, 2011 2:34 pm
Hi there,
With SQL CE 4 been released last month does the current version of installaware support it? I am looking packaging an application that requires this and want to be sure installaware can add it before shelling out on a purchase that doesnt do what I need.
royisher
Re: SQL CE 4 Support
Postby royisher » Wed Feb 09, 2011 6:04 am
We currently do not support SQL CE 4. However, this can be easily support by editing one of our scripts. I will ask support to follow you up on this.
Thank you.
Royi Sher
InstallAware Marketing & Sales
shanep
Postby shanep » Thu Feb 10, 2011 2:56 pm
Thanks Royisher I look forward to receiving further information.
giaviv
Postby giaviv » Thu Feb 17, 2011 2:46 am
Dear shanep,
Here are the SQL 4 CE runtimes:
http://www.installaware.com/forum/viewt ... 348#p23852
shanep
Postby shanep » Thu Feb 17, 2011 9:20 pm
Thank you that works nicely. However it has led me to my next problem.
Inside Application Runtimes I have selected both x64 & x86 versions of the SQLCE4, I don't know what version of the os the user is using so I need this to install whatever version of the os the person is using.
How do I modify the script to only require installing the relevant version of sql ce4?
SHane
bokkie
Postby bokkie » Fri Feb 18, 2011 5:19 am
In the MSIcode there is a Get System Settings statement. That might be of use as you can get system settings returned to a variable and you could place the include script statements the runtime selections produce for you inside "if" statements.
Get System Settings has a capability listed in the pulldown called "Windows in 64 bit mode".
Is that what you want to do?
Return to “Non-Technical”
Users browsing this forum: No registered users and 5 guests
