Minimizing IA 10.10 causing problems with field edits.
ckaware
Post by ckaware »
If you minimize the InstallAware 10.10 Studio Admin window (for example under the properties page) then maximize the InstallAware 10.10 window, the fields are no longer editable unless you change your view from Design to MSI and back to Design... :!:
After minimizing the window (sometimes you have to minimize 2 or 3 times to duplicate the issue.)
Before minimizing the window (the fields are editable.)
giaviv
Re: Minimizing IA 10.10 causing problems with field edits.
Post by giaviv »
Dear ckaware,
This problem does not happen on my 10.0 Studio Admin.
Which OS are you running this on?
ckaware
Post by ckaware »
Windows 7 x64 and Windows 7 x64 SP1.
giaviv
Post by giaviv »
That it exactly my system.
Perhaps try to uninstall InstallAware, regenerate your license, reinstall InstallAware and install your license.
