Setting "Next" button as disabled
chakresh
Post by chakresh »
Need help , I am trying to set the "Next" button on the dialog as disabled if all the items in the checklistbox on that dialog are unchecked. Any suggested solution ?
giaviv
Re: Setting "Next" button as disabled
Post by giaviv »
Dear chakresh,
That's unfortunately not possible. However you can check the values when Next is press, and if nothing is selected you can show an error messagebox and display the dialog again.
