I like what I see so far. Great job!
I do need some help. I have created a dialog that asks if a user will use a touchscreen monitor. There are two radio buttons - yes and no. On the object behavior tab, I put yesTouchscreen for the "Writes to variable" box and noTouchscreen for the no radio button.
I need to write to the registry based on a "yes" selection. I tried an if statement in the code, but it says the variables are not defined.
Thanks for the help.
Brian
Variables and Radio Buttons
Thank you for your quick reply. I am now having no errors, but running the install and selecting the yes radio button does not write the registry information as expected.
The attached file shows the code for my touchscreen. It is not writing to the registry if I select the yes radio button. yesTocuhscreen is the variable where the radio button writes to. Am I correct that yesTouchscreen will be TRUE if the readio button is checked and FALSE if it is not checked?
InstallAware.txt
InstallAware.txt
