Lots of trailing white-space in file's description field
alma88
Post by alma88 »
While checking the final installation .exe produced by InstallAware 11, I noticed that the Description field in the .exe's file properties is way too long. It is much longer than the actual string specified in the InstallAware field, actually all the text is there but with a lot of white-space padding after it. Is there some way I can avoid the extra trailing spaces?
Dinos
giaviv
Re: Lots of trailing white-space in file's description field
Post by giaviv »
Dinos,
What tool are you using to examine the description string?
alma88
Post by alma88 »
Windows Explorer. Right click on the file, select Properties, use mouse to select the Description field in the General tab.
giaviv
Post by giaviv »
Dinos,
We pad the description with spaces when building the EXE and then just write characters as needed. I apologize for the inconvenience.
alma88
Post by alma88 »
Thanks. So there will be a fix for this?
giaviv
Post by giaviv »
This is not a bug, its just the way that InstallAware writes the description. Therefore, we don't expect to change it anytime soon.
Again, I apologize for the inconvenience.
alma88
Post by alma88 »
It is pointless and quite uncommon for useless white space to be trailing a description. Other installers do seem to be able to avoid adding the extra white space, is there a particular reason why IA can't follow them?
giaviv
Post by giaviv »
alma88,
Again, I apologize for the inconvenience caused by this, but this is the way InstallAware is designed as of now. This might change in future version but we cannot guarantee when. Thank you for your understanding.
