How do you persist user-defined variables?
slang
Postby slang » Tue Mar 28, 2006 2:52 pm
Is there a way to persist a set of user-defined variables (other than writing to registry or external file) at first time install and reference those variables at a maintenance install? I thought IA persisted variables automatically but it appears only to do so for certain variables that it knows about.
Steve Lang
JeVal Software Engineering
Postby MichaelNesmith » Tue Mar 28, 2006 4:11 pm
Yes, this is true. Only known variables are persisted. If you think all variables should be persisted, this could be added as a feature request. In the past it was suggested that having all variables persisted at the end of the install might lead to strange situations when setup is started again (ex: if the reboot variable was true, setup would restart expecting to reboot again).
slang
Postby slang » Tue Mar 28, 2006 4:37 pm
Thanks Michael for the response.
Having all variables persisted would be a great help.
One can always initialize (or reinitialize) variables such as REBOOTNOW and REBOOTCOMPUTER so as to maintain proper program flow. Alternatively, the Set Variable command could have a persistance option that one would select on a per-variable basis.
When user-defined variables are not persisted, then it becomes very difficult to support new dialogs that solicit additional setup info. When setup is run in MAINTENANCE mode, user-defined variable context is lost, resulting in modify and repair installs not working properly. Presently, in order to maintain context, one has to write user-defined variables to an external file or a registry key at the end of a first-time install and then read them back in on a MAINTENANCE install. This is cumbersome and would be simplified if user-defined variables were persisted.
I cast my vote for adding user-defined variable persistance as a feature request.
Thanks for considering this issue.
Steve Lang
Postby MichaelNesmith » Tue Mar 28, 2006 4:56 pm
That's a good suggestion! I think we'll see some action on that item.
MikeFieger
Postby MikeFieger » Wed Mar 29, 2006 3:22 am
slang wrote:
"Alternatively, the Set Variable command could have a persistance option that one would select on a per-variable basis."
I think this is a very good idea. I also wanted to have such a feature as I could remove some registry entries then, which I only made for the installer to remember... :-)
