How to edit an installed ini file
crustyzz
Postby crustyzz » Fri Mar 31, 2006 6:26 am
I would like to edit an ini file wich will be installed. But I read I can't call Edit Ini file after the Apply Install command because this is a Windows Installer command.
Should I call Edit Ini File command before Apply install (in the DEFINE WEB MEDIA bloc ?) using SFXPATH valiable, to edit my ini file?
I would like something like that.
Install Files E:\\MyLocalFilePath\\MyIniFile.opt to $TARGETDIR$\\MyDestDir\\MyIniFile.opt
Apply Install (get result into variable success)
If Varible MyCustomVariable Equals 1
  Edit INI File $TARGETDIR$\\MyDestDir\\MyIniFile.opt, [MySection] var=value1
else
    Edit INI File $TARGETDIR$\\MyDestDir\\MyIniFile.opt, [MySection] var=value2
End
But this doesn't work !
Can you help please ?
jimo
Postby jimo » Fri Mar 31, 2006 9:21 am
Move your edits before the apply install but after the file installation.
As in:
else
End
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
crustyzz
Postby crustyzz » Fri Mar 31, 2006 9:57 am
Thanks Jimo,
but this doen't work. I think it's because MyIniFile.opt isn't copied to local system until the script call Apply Install.
In fact the test "Does File exist $TARGETDIR$/../MyIniFile.opt" return FALSE before I call "Apply Install" but TRUE after.
:cry:
jimo
Postby jimo » Fri Mar 31, 2006 10:07 am
I use this all the time,
I install my ini files then use Edit INI File
Here is an excerpt from one of my functioning scripts
Install Files E:\\MDDI_INSTALL\\DIR_ROOT\\Program Files\\MultiMedia Dental\\MDDI\\ctpCore.ini to $TARGETDIR$\\MDDI
Edit INI File $TARGETDIR$\\MDDI\\ctpCore.ini, [CONFIG] Practitioner=$CONFIG_PRACTICE_NAME$
Edit INI File $TARGETDIR$\\MDDI\\ctpCore.ini, [CONFIG] StatusTemplatePath=$MASTER_IMAGES_PATH$\\StatusTemplates
Jim Oswell
crustyzz
Postby crustyzz » Mon Apr 03, 2006 8:13 am
Thanks Jimo for your help.
That works !
BUT ... My Ini file contains a checksum :oops: and I would like to calculate the new checksum when the file will be copied, and Edit the file to update a value.
I'm developping a plugin in order to calculate the new check sum.
I hope I would be able to edit my ini file just after the last editions.
I saw a "File contains a checksum" check box in the file properties, but I don't know how to use it.
Does anybody know more about this option?
Postby MichaelNesmith » Mon Apr 03, 2006 3:00 pm
The checksum option is for when you're installing files. From what I understand you are storing the INI checksum as part of the INI file itself, so that's not what you're looking for.
Users browsing this forum: No registered users and 57 guests
