I have just upgraded my InstallAware from 10 to 12, but can no longer compile the project.
After a little bit of investigation, there is a probably invalid line of code
Set Variable {127AB9EB-89BB-44EA-A60D-899DC30D4E40} to PROGRESSTEXTCode: Select all
Set Variable SHORTCUTFILESALL to $SHORTCUTFILES$Code: Select all
Set Variable {00281FC2-E74B-419B-A667-86DDFB4AEC1D} to SUCCESSSo,
a) how do I fix that line to the correct value?
b) is the List Index error going to be fixed in a future release/bugfix/patch?
c) Any ideas how that line of code switched itself to the invalid line in the first place? (I couldn't see any modifications made that were anything to do with that line in SVN repo)
If not, I guess I'll have to stick to Installaware 10...
On a side note: I installed IA12 after uninstalling 10, installed my licence, IA12 worked fine, but when i tried to compile i was missing a plugin. I added the plugin through the installer with the add more features option, and now I have to reinstall the licence again... Is that really the expected functionality, cause it seems a bit unnecessary to reinstall the licence after adding a plugin....
