how to create timed trial installation
coder12345
Postby coder12345 » Sun May 07, 2006 8:08 pm
Does installaware support anti-piracy and/or trial installations? Can I create installations that are set to expire in a year or in a month?
Is installaware compatible with other third-party anti-piracy software that employs the use of keys and machineIDs?
Thanks!
coder12345
Postby MichaelNesmith » Mon May 08, 2006 1:01 am
I'm not sure what you mean by InstallAware being compatible with third party anti piracy software. Such software is typically used to wrap your application, not installer - so I don't think that is a concern.
About your other question - sure, you can use InstallAware to build expiring installers. See the Serial Number Generator and Online User Authentication examples for ideas.
Gizm0
Re: how to create timed trial installation
Postby Gizm0 » Tue May 09, 2006 5:23 am
coder12345 wrote:Hi,
Thanks!
coder12345
You can give WinLicense a try from www.oreans.com..
Panagiotis Kefalidis
Software Design Team Lead
coder12345
I'll give it a whirl...
Postby coder12345 » Wed May 10, 2006 12:32 pm
Thanks for the suggestions...I'll give them all a try.
Users browsing this forum: No registered users and 48 guests
