Hi, I have a serious problem when I have to change the Setup Version in my Project.
I use InstallaWare 2012 on a Windows 7 32bit machine.
Here the steps :
1) -I have created a Setup Project with 9.00 version value.
2) -I have launched the Setup and installed my application.
3)- Later I have re-open the Setup project and changed the Version paramenter to 9.10 value
4) - I have launched again the new Setup program
5) - The Setup program uninstalled the old 9.00 version but when the installation process start it have displaied the following error :
If I run the Setup with the /l parameter it produce an empty log.
If I produce a new Setup but with 9.00 version again, it works fine.
This problem exists for all my setup projects.
Please help me to resolve this problem.
Thank you all.
ERROR changing Setup Version
Re: ERROR changing Setup Version
Here there is the Windows Event Viewer log of the Setup Error :
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="MsiInstaller" />
<EventID Qualifiers="0">1013</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-10-05T09:15:34.000000000Z" />
<EventRecordID>67040</EventRecordID>
<Channel>Application</Channel>
<Computer>xxxxxxxxxx</Computer>
<Security UserID="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" />
</System>
- <EventData>
<Data>Product: xxxxxxxxxxxxxxxxxxxxxxxxxxx --</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data />
<Binary>7B41323743423638452D373541392D343743362D384344452D3439413339323842384334397D</Binary>
</EventData>
</Event>
- <System>
<Level>2</Level>
<Task>0</Task>
</System>
- <EventData>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data>(NULL)</Data>
<Data />
</EventData>
</Event>
More Detail : The error occurs when is execute "Apply Install..." command of the Setup project.
And so I can't debug it more over.
for what you said, seems that you are able to replicate the with any project.
If so, can you post a very basic project that reproduce the error?
Of couse I will verify it.
