I use IA15 and I am trying to get a script running.
The script at all is about 3MB big. -> When I run the script in DOS Box with the following command:
mysql -uUSER -P3306 < "Path\Script.sql" then the script will be imported correct
First: When I use Run Program from IA built in, then the Script isn't running
(But I can't see the error, because the dos box imediatly Closes)
Second: I use the built in Script Editor of IA15. - This always Ends when the code Comes to the following lines:
DELIMITER $$
/*!50003 DROP TRIGGER*//*!50032 IF EXISTS */ /*!50003 `iCodeDatSeit` */$$
/*!50003 CREATE */ /*!50017 DEFINER ...THX
