Hello
A customer told me that he has problems with InstallAware Setup on some PCs.
The is a process net.exe and net1.exe which stopps the installer routine. When he kills the process in the taskmanager
the setup will proceed.
I have no idea what net.exe or net1.exe is, I do not use this in my MSI code
Is this an part of InstallAware?
Have you any idea?
regards
Hans
net.exe net1.exe
Re: net.exe net1.exe
Dear Hans,
For what I know, the Net.exe Utility component is a command-line tool that controls users, groups, services, and network connections.
Doing a quick google search i found the following link, maybe you can found it useful.
http://forums.techguy.org/virus-other-malware-removal/698767-please-help-net-exe-net1.html
Dear Francesco,
thank you.
What I want to know is:
InstallAware itself or some build in features do not use "net.exe" or "net1.exe?
Because I do not know why this is in the taskmanager while installing the software.
I do not call such a exe in my MSI code
Could it be that some plugins of InstallaWare do this?
regards
Hans
thank you.
regards
Hans
Dear Hans,
for sure an InstallAware package doesn't call those processes, if a third party plugin does the same ... honestly I don't know.
Of course, official IA plugins don't.
PS.
I suggest to you also to verify if any Antivirus software runs some strange process.
PS.
Just a quick guess: does the installer in any way involve any handling of services?
One common use for net.exe is to restart a service, for example:
net stop spooler
net start spooler
If the service has dependencies ("spooler" in this example) net.exe will prompt with a yes/no question and this will result in two instances of net.exe (one of the named "net1") showing up in taskmanager. If there is no console for I/O (hidden window for example) the process will hang.
If your installer somehow need to do something related to services a hanging net.exe might cause your installer to a hang.
The net.exe may be a result from a login script or something?
This is just a guess from my side. If it turns out to be something like this that causes your problem, make sure that whatever uses net stop/start uses the "/y"-switch.
net stop spooler
net start spooler
Users browsing this forum: Google Adsense [Bot] and 54 guests
